welding new wear plates over old ones
发表于 2021-9-1 00:06:32 | 显示全部楼层 |阅读模式
OK, never did wear plates. they are on a 1999 Geith excavator bucket, both lateral and side plates. will use 7018 rod and will preheat and wrap with blanket. My question is. Is it ok to weld the new ones with out removing the old ones? Some are almost gone already. In those places I will add 3/4'' AR400 and where there is material left I will and 3/8'' AR400. Also, the customer would like to piece in small pieces over the old side plates rather than try to make the radius...is this going to be effective? Bucket is 2' wide.
Reply:I cut the old stuff OFF.   Start fresh and only have YOUR welds holding the new stuff on."Before I put new stuff on, I need to remove all the Old Sh*t"   The new wear plates will not fit right anyhow.  Old ones are worn on a taper correct?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RI cut the old stuff OFF.   Start fresh and only have YOUR welds holding the new stuff on."Before I put new stuff on, I need to remove all the Old Sh*t"   The new wear plates will not fit right anyhow.  Old ones are worn on a taper correct?David
Reply:Yes. You are correct. One of them is on a taper, one almost totally gone, and the third one is even.
Reply:Take the old off before putting the new on.  When one of the welds cracks on the old liner, and it will, your new liner will go with it.  Not to mention the poor fit up over the worn plates."The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:Originally Posted by ironsharpensironOK, never did wear plates. they are on a 1999 Geith excavator bucket, both lateral and side plates. will use 7018 rod and will preheat and wrap with blanket. My question is. Is it ok to weld the new ones with out removing the old ones? Some are almost gone already. In those places I will add 3/4'' AR400 and where there is material left I will and 3/8'' AR400. Also, the customer would like to piece in small pieces over the old side plates rather than try to make the radius...is this going to be effective? Bucket is 2' wide.
Reply:And see if the customer will go for putting hard rod on the areas of the wear plates that wear fastest ie: the leading edges.                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Scarf the old off and weld the new on.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:http://weldingweb.com/vbb/showthread.php?t=38080Here is a bucket edge I did a while ago.Small (18"  maybe 24")  excavator bucket in my shop today, waiting for the edge to show up.DavidLast edited by David R; 11-04-2011 at 06:05 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Thanks alot! Makes alot of sense. Out with the old an in with the new!The bucket is actually 30" wide. I guess I will have to O/A torch mout the old ones? I am unfamiliar with arch gouging.  Amother problem I have is these giant side plate Which the customer can't afford to cut out.! Too much money for that. I can replace the laterals but have to figure out something else for the side plates. Any suggestions?
Reply:Originally Posted by ironsharpensiron Amother problem I have is these giant side plate Which the customer can't afford to cut out.! Too much money for that. I can replace the laterals but have to figure out something else for the side plates. Any suggestions?
Reply:If he can't afford it, then you can't do it.   Simple eh?Real world weldin.  When I grow up I want to be a tig weldor.
Reply:[EMAIL="[email protected][/EMAIL] aha ing trouble with the pics. Will have to figure it out after the weekend. Thanks for the help. Will post pics and keep you informed on progress.
GMT+8, 2025-12-23 16:33 , Processed in 0.091600 second(s), 18 queries .
