Where do you hold your tungstens?
发表于 2021-9-1 00:06:30 | 显示全部楼层 |阅读模式
Lets see where everyone puts their hot, dipped tungstens, and the clean ones while they are welding?I ran this up todayone to hold the good ones, one to hold the dirty hot ones and the longer one to hold some short filler for tacking.Never thought to weld one at a time. I tacked them all and then had to reach in betweenI was supprised how well the welds looked (for me) on 3/4" pipe (1" ish OD)So what do U use??? Attached ImagesG
Reply:That's a cool idea.  It sure beats having them rolling around the table and falling on the floor
Reply:Dude !Great Idea....  Gonna have to rig myself something like that up ASAP.  Haven't used the new welder much as it's 'soft water' Fishing season here but damn,.... well done !  Good looking welds too...Cheers,/Jman..
Reply:Originally Posted by PowerstrokedThat's a cool idea.  It sure beats having them ..................... ..... ......... falling on the floor
Reply:I have a small fishing tackle box (maybe 4" by 10"by 1" tall).  I keep the tungstun, cups, collets, lenses, etc.  It has dividers and keeps everything in it's proper place!Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Fishing tackle box is what I use!
Reply:I dont bother, I just grind as needed.  Point both ends at once, run them until you cant anymore and resharpen.  My grinder is only 10ft from where I weld.Have we all gone mad?
Reply:why does everyone have coins in the pictures? is there a purpose to it, or just for showing the size?i'v only been welding a few months and never seen it.
Reply:Here is my holder. This one is made from scrap stainless. I had one made out of carbon pipe, with mexican pesos on it, it got stolen. One day I will make another so I can keep the tungstens separate.  All of my work is in the field, so I made this type to fit in my back pocket.  I don't use tig much, but I keep my tig rig, some argon gas, stainless rod and mig wire on my truck, to get me by. Attached Images
Reply:Originally Posted by KYZAACwhy does everyone have coins in the pictures? is there a purpose to it, or just for showing the size?I've only been welding a few months and never seen it.
Reply:I guess it has to be said; don't put the used ones in your shirt pocket!!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2025-12-23 18:13 , Processed in 0.097774 second(s), 18 queries .
