1/2" pipe bending unit
发表于 2021-9-1 00:06:28 | 显示全部楼层 |阅读模式
Hello folks, here is another bending unit, this one is meant to bend 1/2" black iron pipe. It is a double wrap-around type and uses a 5 ton hydraulic long ram. As it is currently set up it will make up to approximately a 120 degree bend. I have used it to bend various rack frames for quads and other items our of pipe. This particular unit doesn't have interchangeable die sizes. As with any powered unit that has stored energy, you need to be mindful of where you position your body and that of others while you are using it. Best regards, AllanI should have included this first-off, would love to see anyone elses versions of similar types of equipment. Thanks! Attached ImagesLast edited by aevald; 07-31-2009 at 02:56 PM.aevald
Reply:Thats slick, I like it.
Reply:i like it to you could make diff dies for other things
Reply:Very cool setup...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Any write up on plans?  I'd love to build something like this for up to 3" piping.
Reply:Originally Posted by BustedsmAny write up on plans?  I'd love to build something like this for up to 3" piping.
Reply:that's not a new concept.  It's just a home made version of one of these...Not bagging on ya, just pointing it out. Attached Images
Reply:Originally Posted by Boostinjdmthat's not a new concept.  It's just a home made version of one of these...Not bagging on ya, just pointing it out.
Reply:Originally Posted by aametalmasterMy buddy has one that looks like yours for doing exhausts. Cool unit...Bob
GMT+8, 2025-12-23 16:33 , Processed in 0.086112 second(s), 18 queries .
