mower deck repair
发表于 2021-9-1 00:06:26 | 显示全部楼层 |阅读模式
Land lord runs into water meter, now blade hits deck Tried porta power but no go. Cut slits and hammered out. Also cut off worn out flange at botom. Migged w/70s6 3 1/8x1 straps over slits inside and out. Weld-bend-weld-bend some 3/16x1/2 to form new flange. Ground the welds and painted.Peter Attached Images
Reply:2 more Attached Images
Reply:Nice save.How did the water meter fair in the battle?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Nice save.ThanksHow did the water meter fair in the battle?
Reply:Deformed metal is the pits.  I think it can be even worse on a round shape.I think, and I'm not sure it's right, that the reason pressure vessels are round is because they do such a good job at resisting pressure from inside.  The very same reason your porta power didn't make a dent in the redo.Slotting was the answer"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Pushing on the round may move it a bit, but the rest of the round will try to flatten/straighten to compensate for the pushing you'r trying to do.and you wonder why I have so many posts.  ROFLMAO"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice redo on the guard.  Speaking of guards, sounds like someone needs a small, custom-welded fence around his water meter ... could be a job looking for the right person to take it on .....
Reply:Originally Posted by farmersammPushing on the round may move it a bit, but the rest of the round will try to flatten/straighten to compensate for the pushing you'r trying to do.and you wonder why I have so many posts.  ROFLMAO
Reply:Originally Posted by SpyGuyNice redo on the guard.  Speaking of guards, sounds like someone needs a small, custom-welded fence around his water meter ... could be a job looking for the right person to take it on .....
Reply:great work easy $$$
Reply:Originally Posted by ed macgreat work easy $$$
GMT+8, 2025-12-23 16:32 , Processed in 0.108782 second(s), 18 queries .
