Tube welds done on exo
发表于 2021-9-1 00:06:19 | 显示全部楼层 |阅读模式
Here is a project we have almost finished.   Must say I like mig alot better then flux core but I wish I was better.   So be harsh so I can learnWelded with a MillerMatic 252 that I bought a month ago.  Just started migging 3 weeks ago.Settings16.8 volts245 wire speed20 CFM Attached Images
Reply:And about finished Attached Images
Reply:Looks like a nice project.  How about some info on it? What axles? Suspension set up? Tires? Driveline?Only two defining forces have ever offered to die for you, Jesus Christ and the American G. I. One died for your soul, the other for your freedom.
Reply:Sorry if this is short on blackberry right now65In front diamond axle Fj80 high diff 4.88 arbLongfield axlesChromo gun gears63in diamond axleNon trd rear 4.88 arb Full floater with chromo shaftsMarlin doubler2.7 engineWhat used to be a 98 tacomaAll tubing is DOM 1.75in.   .120 wallFront range solid axle swap kit
Reply:About the only thing I can pick on is the first pic.... a little too dark. Other than that, it looks great! That's gonna be one badass rock crawler.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Originally Posted by RojodiabloAbout the only thing I can pick on is the first pic.... a little too dark. Other than that, it looks great! That's gonna be one badass rock crawler.
Reply:Originally Posted by ducI was just afraid of the look of the weld strength or it was proper.   Tube is a pain in the *** to weld.   Hard to follow around.
Reply:Originally Posted by RojodiabloOh, I agree. To try and chase the bead all the way around a tube usually gets me burned on at least one arm, and maybe my neck or shoulder!!! It is a great way to learn each technique... up, down, flat, and inverted. The welds look good. Heat looks O.K., the beads are good, the fit-up is good. You really can't ask for more than that.
Reply:Kick *** truck... welds can be better but... i´ll let a pro critique dat...My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I'm not a pro, but.....Make small circles when you weld.  The forward part going in the up direction.   OR you could move back and forth from piece to piece in a Z or C or U motion.  Your welds will look better.  Try it.Sorry, these are not on tubes. but......  When Mig welding, you have to weld the two pieces together. Stick welding you weld the groove.Very nice roll cage.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I would say slow your feed a little and take a little more time smoothing out the pool and you can get results like David's that look tiged.
Reply:Originally Posted by ducHere is a project we have almost finished.   Must say I like mig alot better then flux core but I wish I was better.  MillerMatic 252Settings16.8 volts245 wire speed20 CFM
Reply:Are you done? I think you should beef it up a bit more while your at it.
Reply:My cage was done using the cirlce patternNice rig Heres my Fj 40 weld it like you own it
Reply:is this what you guys mean as a "C" pattern? Could I get a little more info?
Reply:Right on! I have a fj40 and a sasd 4runner that is setup very close to your taco but I still have the 22re.
Reply:Originally Posted by richharris this what you guys mean as a "C" pattern? Could I get a little more info?
Reply:what is the roll cage welding standard in the usa? over here you must be a certified welder or show that you can weld to that standard.the day you stop learning in this tradeis the day your in your grave
Reply:Originally Posted by paretrooperwhat is the roll cage welding standard in the usa? over here you must be a certified welder or show that you can weld to that standard.
Reply:Originally Posted by SupeNone.  And with some of what I've seen at the track or even come through the shop I worked at, it's a scary proposition.
GMT+8, 2025-12-23 16:32 , Processed in 0.070071 second(s), 18 queries .
