Exhaust Mig and stick
发表于 2021-9-1 00:06:17 | 显示全部楼层 |阅读模式
I had to weld a pipe on my own car yesterday.  I did the end with the big gap with my SP100.  I did the other end with 1/16 6013 to see if I could do it.  Not really.The pipe was in pretty good shape.  I went over it quite well with the chipping hammer and a wire brush.I turned it up a little hereLast edited by David R; 10-31-2007 at 12:46 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:With the stick, I tried 45 amps, then 35, then settled on 40 or so.  My down hand welding sucks.  I almost never use that method with stick.  MIG was vertical down.  I learned here you can do that. Stick, 6013 DCEN 40 ampsLast edited by David R; 10-31-2007 at 12:55 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:and the rest.LOVE that 110 Volt MIG.  I haven't stick welded an exhaust in 20 years, now I remember why.DavidNot afraid to post ugly welds Settings for the SP 100 were 3 and D I move both knobs the same amount to adjust up or down.  Wire .o23, C/25 @ 15 cfh.Which process would you use?The  vice grips are my ground clamp.DavidLast edited by David R; 10-31-2007 at 01:33 PM.Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-23 16:26 , Processed in 0.092862 second(s), 18 queries .
