MIG verticle up
发表于 2021-9-1 00:06:15 | 显示全部楼层 |阅读模式
My verticle up with a MIG. 12mm plate, the leg length of the weld is 12mm the distance from toe to toe is 25mm.I wish I had a better camera, I did this weld consistantly all the way for 22cm, thats when the plate finished.  :lol:
Reply:Perfect!DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I wouldn't say perfect but not bad. --Gol'
Reply:beautiful work mat,
Reply:...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:did you do that with one root pass and one cover pass. our welding instructor at my work had us do a zig zag root and then a triangle shaped cover. that was on 3/8 plate
Reply:not shure what  mm is   but the weld is text book ChuckASME Pressure Vessel welder
Reply:Originally Posted by down19992000did you do that with one root pass and one cover pass. our welding instructor at my work had us do a zig zag root and then a triangle shaped cover. that was on 3/8 plate
Reply:Originally Posted by chopper5not shure what  mm is   but the weld is text book
Reply:yes looks good but if you keep the weaves closer together there is a less chance of cracking understress.6G zirconium 702 GTAW 2" xxheavy6G P.E.D. carbon steel GTAW 2" xxheavy3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4" 3G 316L stainless GTAW up to 1" 3G carbon steel GTAW up to 1" 3G Hastalloy GTAW up to 3/4"1G tantalum GTAW up to .060"
Reply:That's one of the best uphill weaves I have seen in a long time. Really consistent on the edges of the weld. Great job.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Dude thats great ............good enough for union work Hardley ever two welds are the same weld it like you own it
GMT+8, 2025-12-23 16:31 , Processed in 0.088451 second(s), 18 queries .
