Welding up a car frame
发表于 2021-9-1 00:06:13 | 显示全部楼层 |阅读模式
Hey guys, I'm an old newbie.  I've been welding for years, but never have been great at it.  The knowledge you guys pass on has made itself obvious in the improvements in my skill since I found you!I am restoring/upgrading a late 70's Camaro, and it seems prudent to weld all those seams in the front subframe before I put it back in the car.  I have two machines that I could use- a Hobart Stickmate AC/DC stick welder and a Lincoln SP-135T.  The Stickmate is up to the task I'm sure, but requires more skill.If it were up to you and these were what you had to work with:Would you do it at all (am I too limited by the equipment)?Which machine would you use if you'd do it?If stick, what rod would you use?Did I leave out any important bits of information?Hobart Stickmate LX AC/DC, Millermatic 252 & 30A spoolgun, Thermal Arc 185 TIG, Miller BWESmith Oxy-AcBridgeport 2J , South Bend 42" 9AHusky 7.5 HP 22.3 CFM 80 gal compressor
Reply:Sp135.  ER 70S-6 wire and 75/25 Argon/CO2 Gas, welcome  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:I did my 68 with my 100 wire feed,35 wire , after I sand blasted the whole thing. I welded up the seams, cleaned up the welds, smoothed with seam sealer then painted with sem gloss black. wow what a nice look.
GMT+8, 2025-12-23 16:31 , Processed in 0.068070 second(s), 18 queries .
