pow con 550smp
发表于 2021-9-1 00:06:05 | 显示全部楼层 |阅读模式
does any one know if this welder can be changed from 3phase to 1 phase?
Reply:Arc Products POWCON Manual DownloadsWeller 15W
Reply:Im pretty sure thats one of the powcon units that cannot be changed.     If your located anywhere near California i would be willing to consider its purchase from you should you not be able to get it to work on single phase.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-23 16:26 , Processed in 0.093124 second(s), 18 queries .
