HiI bought this machine, but I do not like the quality of the welding wire to each other. I think, that it's all about options, but I have no instructions. Maybe someone knows what these symbols mean?When selling dealer told me only senses only for third and fourth characters:power of pressing (3) and welding (4).please help!updI'm sorry, I mixed up the name and photo of machine. This is Sureweld PBP 16 Spot Welders 15KVA [IMGhttp://vk.com/photo81554375_270882404[/IMG]Last edited by Konstantin; 11-01-2011 at 01:46 PM.
Reply:I found the manual, but I do not understand what it means.1. Pre weld squeeze time 0-99 cycles2. Slope up of weld power 0-20 cycles3. Weld time (set 1) 0-99 cycles4. Weld power (set 1) 1-99% of transformer output5. Weld time (set 2)6. Weld power (set2)7. Number of pulses 1-20 (If set 2 or higher weld time is 20 cycles max)8. Time off between pulses 0-99 cycles9. Post weld forge time 0-99 cycles10. If set 2 or higher gives repeat weld 0-99 cycles (time between cycle)11. Energy compensation – for use on dirty or oxidised sheetsIs cycles is seconds?For what 1 and 2?
Reply:Cycles makes me think its talking about your AC power cycles, In the US its 60hz (cycles per second) many countries are 50hz. Im just guessing at this and could be wrong.
Reply:Hey Konstantin,You are leaving out a lot of information for the members to try to discern. Please post a pic of the entire unit, pics of what accessories are with it, & the processes it is made to do, ie, TIG/MIG/SMAW. The pic you posted looks to be the control panel settings for process & parameters of heat/freq., etc.. I am going to guess the manufacturer, according to your thread title, is Meritus ATB T-Butt Welder & I've never myself heard of that manufacturer, so, I presume it is European. Give us more data & what you are seeking as far as setting up the controls.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Sorry for the silence.repeat, now I write not about meritus ATB T-butt Welder, about 16 Sureweld PBP Spot Welders 15KVA. With meritus ATB T-butt Welder I also had problems, but he has differ control system.manufacturer: sureweld (UK)manual to control http://www.sureweld.co.uk/uploads/pr...%20c2%20px.pdfcycle is really associated with fluctuations in electricity. I think that in this case, the cycle of about half a second.5 and 6 in my machine doesn't work. This seems to be to control a second welding (I have only one)Now all work well (find the optimal parameters for each weld my part). If anyone is interested, I can barely write a setup1 - only for good ficsation2 - i don't know, what does it mean, but it influence on result3 - The longer - the stronger the metal melts.If set on "11" value 1, then there is some minimum time welding about 5 seconds and machine does not react even if the "3" set value 2 (around 1 second).4 - Weld power. It's simple7 - Probably the number of times current passes through.8 - I set value 1. Because I have seen, that on short time metall become more hot.9 - If you want to fuse in well the two parts ещ each other, after the intense heat, they need to for a long time (10-15 seconds), be hold.10 - I don't want to repeat weld cycle, therefore I set 0. I set up the details, I press the pedal. I wait, when the machine will do all operations. When the electrodes are unclenched, I release the pedal.
Reply:Photos:meritus ATB T-butt Welder
Reply:6 Sureweld PBP Spot Welders 15KVA |
