mig
发表于 2021-9-1 00:06:03 | 显示全部楼层 |阅读模式
OK, mig push or drag?And why?Tim Beeker.
Reply:What ever feels good , both work fine , depends on how you feel body position ,fatigue , you will figure out what works good for you , you will figure what works for you after some time under the hood
Reply:Jesus Christ,Nearly 800 posts and you haven't found the search feature yet.This subject has been discussed in detail in multiple posts.Pushing gives a flatter bead profile and less penetration.Dragging/pulling gives deeper penetration but a higher bead profile.This sounds like a question asked by a new poster who just bought his first 120v mig machine.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Dragging creates less spatter, but reality is.... it really depends on the specific joint you are welding and how you need to control the heat(distortion)..... I all ways try to drag rather than push no matter which direction I am going(left-right) vertical (up or down) or overhead..... (same as flat)Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Originally Posted by SundownIIIJesus Christ, Nearly 800 posts and you haven't found the search feature yet. This subject has been discussed in detail in multiple posts.
Reply:Originally Posted by SundownIIIJesus Christ,Nearly 800 posts and you haven't found the search feature yet.This subject has been discussed in detail in multiple posts.Pushing gives a flatter bead profile and less penetration.Dragging/pulling gives deeper penetration but a higher bead profile.This sounds like a question asked by a new poster who just bought his first 120v mig machine.
Reply:Yeah I only had a few minutes last night on the net, search ate up a few of those unsuccessful.So I threw this out there. Don't like then don't read it and **** off.I always pushed but had to pull because of position, I was surprised how much more penetration I got.Slag you drag I always heard.My neighbor lady wanted to try welding so I set up the 200, she had a hard time seeing the puddle pushing, pulling was much easier for her.sundown111 I was hoping you would be in bed and not see this, I am glad you had something to bitchabout.Tim Beeker.
Reply:Right from Miller. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:That's so odd.. I always find it easier to pull.  I can play around with the puddle a lot better in my opinion.Maybe I'll try some push..  nah.JoeMiller 140 Autoset (2010)Miller Syncrowave 250 (1996)
GMT+8, 2025-12-23 16:31 , Processed in 0.068961 second(s), 18 queries .
