And the cow jumped over the moon...
发表于 2021-9-1 00:06:01 | 显示全部楼层 |阅读模式
Here's a little project I did this weekend.  It was mostly cutting, with a little welding.  The columns are concrete culverts stood on end and filled with dirt... about 6 years ago.  It took me a while to figure out what I wanted to put on top, so as you can see the ivy had a little time to get established.The arch is constructed of some heavy 8" channel that came out of my old shop, and the cow was cut out of some 3/16 plate that was salvaged from an old dump truck bed.I cut the channel with o/a, including the stars; I used plasma on the cow... all freehand.  Welded the big pieces together with the MIG, and stuck the cow on top with some flux core wire in my 110 MIG.I expect the arch should be completely covered with ivy by this time next year. Attached ImagesWork HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:That's way cool.  I like it.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Nice lightning rod.
Reply:Actually..not sure the cows gonna make it...ouch!  ..just kidding.Nice piece!Miller Dynasty 200DXHypertherm PowerMax 45Victor OAIR CompressorLots of blacksmithing tools and other fun toys meant to creatively disfigure, reshape, manipulate and join metal.
Reply:Hey, the cow even looks like a cow. Good work.
Reply:Originally Posted by transitNice lightning rod.
Reply:Originally Posted by Leadhead1911Yeah,  if I could capture 1.21 gigawatts, I could tie it in to the flux capacitor and power the whole compound.... hmmmmm, or I might be able to do something with that old DeLorean behind the barn...
Reply:Originally Posted by transitNot kidding, nice lightning rod. Be careful, you can get hit up to 12 miles away.
Reply:Very nice, did you draw the cow and moon yourself ?http://www.PlasmaMetalCutter.comGiantTech Cut40DGiantTech Cut50DGiantTech CT520DGiantTech Tig200sGiantTech Arc200GiantTech Tig200PACDCMiller MM210No Brand Chinese Chop SawNo Brand Chinese 4" Angle Grinder
Reply:That IS coolBe a shame to see the nice cutwork obscured by ivy though.You guys got that Cudzu down there too???  I hear it's pretty agressive stuff"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by GiantTechGuyVery nice, did you draw the cow and moon yourself ?
Reply:Good work and it shows a lot of creativity. The thing you might add is to experiment with some lighting to show it off at night. I saw a mountain house not long ago with lighting installed in the soffit to show case the house at night. It really made it look pretty. Maybe a little lighting would make the cow look even prettier at night. Again good work.
Reply:Very nice design. I agree with cut back the ivy and put a light on it at night.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-23 16:32 , Processed in 0.093396 second(s), 18 queries .
