Gears
发表于 2021-9-1 00:06:00 | 显示全部楼层 |阅读模式
This was dropped off today.  All ready to be welded.  Nice customer!He asked me to wrap it in wet rags, so I did. Arcmaster 185 floored, positioner pedal under left foot.3/32 tungsten and 3/32 E70S-6   One pass.  Gas lens, #8 cup.Water cooled torch.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Purdy!  That's one big watch gear.I'd assume the smaller gear got damaged/worn out?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Dave, did they have to bush it to bring the bore back to size or did it get gouged real bad? I can't tell looking at the pics.                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:david r where you been? real nice work as usual
Reply:Originally Posted by mla2ofusDave, did they have to bush it to bring the bore back to size or did it get gouged real bad? I can't tell looking at the pics.                               Mike
Reply:OK, just curious. I see the teeth of the small gear now. Good job, as always!!!!                      Thanks,                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Nice job!  Just curious... what's that go to.  Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Originally Posted by Leadhead1911Nice job!  Just curious... what's that go to.
Reply:was the purpose of the wet rags to prevent damage to the heat treated gear teeth?
Reply:Originally Posted by David RIt gos FOR 1/2 hour labor.  What it goes TO I have no clue.Thanks for the compliments David
Reply:sheesh, can't put anything past you guys.  took me 5 minutes to find evidence of a smaller gear...
GMT+8, 2025-12-23 18:10 , Processed in 0.089625 second(s), 18 queries .
