welding nickel 200
发表于 2021-9-1 00:05:58 | 显示全部楼层 |阅读模式
I am taking a pipe weld test on nickel 200 (99.9%) nickel. the test is on 2 inch schedule 10 in the 6g position.  we are allowed 3/32 reinforcement on both root and face. 3/32 root opening max and 5 p s I on inner purge only. I am keyholing the root and seem to do ok but sometimes get too much reinforcement. does anyone have any advice
Reply:sorry guys I made a mistake on my post. I meant to say 1/16 reinforcement on the root and cap. not 3/32
Reply:Are you using.....have you tried  1/16 filler wire?
Reply:no 3/32 is all that's allowed.  and no fusion either.  this is a tough test.
GMT+8, 2025-12-23 16:33 , Processed in 0.091490 second(s), 18 queries .
