Fan Mount
发表于 2021-9-1 00:05:46 | 显示全部楼层 |阅读模式
A customer wants a 60" fan (15hp) mounted in the end of a container so they can get better flow for their airplane motors.  So I spend about 1/2 hour on autocad, 1/2 hour on the saw and another 3 1/4 hours in fabrication and welding.  The material is 1 1/2 x 1 1/2 x .120 square tube, which borders the mounting rings that came with the fan.  I'll try to remember to post pics after I weld it in and run the duct work outside his building. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
GMT+8, 2025-12-23 19:57 , Processed in 0.103040 second(s), 18 queries .
