Welsing Trailer Project
发表于 2021-9-1 00:05:42 | 显示全部楼层 |阅读模式
Well finally got to a finished for not point in my welding trailer project.Here are some pics.Its a 5x8 trailer. Trailblazer 275, Aircompressor and Oxy/Ace Tanks are raised from deck to allow for some metal storage if needed. Also added a few leveling jacks if ever needed. Has Fold Down Table with Vise, Cable Reels, Air Reel and Oxy Ace Reels for convience and storage space reduction.EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:----------------------------Last edited by GunLocators; 07-01-2009 at 05:18 AM.EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:Very nice!  Great idea with the below-deck storage area.   Maybe a tail gate or lip could be added to the rear of it to keep your metal stock in the trailer without having to chain it down?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Building a removeable steel gate for that purpose this week EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:I never worked off of a trailer, But that is one sweet set up for a trailer. Just out of curiosity, are you a little heavy for a single axle?Lincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:Originally Posted by gclampJust out of curiosity, are you a little heavy for a single axle?
Reply:If that trailer has a 3500 lb axle, I'm sure its well under it's limits.   That trailer looks built stronger than my 5x8 single axle utility trailer, yet I have loaded my 3500 to 4000 lb utility body on it and the little trailer didn't complain at all.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:The axle is rated at 3500# also I had HubCity Springs add a heavy duty 5 leaf spring setup should be fineEquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:Good looking trailer and setup. Looks like you put a little thought into it. Should serve it's purpose well. I like the stabalizing jacks, oughta' make for a good work surface.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:Got a question about your lead reel.  I see that you have an isolating block (kitchen cutting board?) but how are you keeping the bolts isolated?  Do you have rubber washers?It's not what you can buy, it's what you can build.
Reply:Very nicely done.welder
Reply:I don't understand the purpose of the isolating board. I  always just hung my cables from hooks on a rack, I never used a reel. Is that standard with reels?Lincoln Ranger 8                        Lincoln 175                          Drill pressLincoln 225 mig                            Plasma                              8 ft brake        52" jump shear
Reply:very nice,.a lot nicer than the mesh floor design seen on another thread.looks like you have everything thought out.
Reply:That is one nice set up.  You have made good use of every inch and the raised deck for the metal is a good touch.  I am glad I seen this thread. We are about to make a welding trailer and our plans are 6X10.  I can see now I'll be able to use the extra 2 feet, but ofcourse that is like building a garage....they are never big enbough.
Reply:What brand is you welding cable real is that. That's a cool trailer hope you don't mind if I take some of your ideas when i build mine..
Reply:I built the reels i had a CNC shop cut the sides and had the bearings pressed by them in the hub areaEquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:Dam you did a great job on it.. It looks like it was manufactured..
Reply:You can get a kit and plans online I do not recall the site get the parts and 6 hours later you have a nice set of reelsEquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:First, I'll say this, your layout is very well thought out,  nice job!  Originally Posted by GunLocatorsThe axle is rated at 3500# also I had HubCity Springs add a heavy duty 5 leaf spring setup should be fine
Reply:I am actually probably going to change the axle and will do the shackle links then If I have this loaded I can already tell I could benefit from elec brakes so I am going with a 5000# axle setup with elec brakes soon It seems to handle well but I think the ride during braking would be better. My 08 Super duty pulls and stops it fine with out a issue but never hurts to over do a little..EquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:Good man, if it ain't broke, upgrade!  City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Any how Mother in law has a small utility trailer that needs a new axle I will be her new fav son in law OH I guess so since I am her only son in law LOLEquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
Reply:Nice looking trailer.  I would check the weight capacity of the tires also.
Reply:Trailers always seem to ride best at 75-80% spring capacity.  Keep that in mind.  Too heavy of springs and it will be a rough ridin SOB.  I would suggest running it across a scale as is before making any changes.
Reply:They are 10ply trailer tiresEquipmentLincoln 200SATrailBlazer 275MillerMatic 252Hypertherm Powermax 600
GMT+8, 2025-12-23 18:11 , Processed in 0.304424 second(s), 18 queries .
