millermatic 175 220 volts
发表于 2021-9-1 00:05:35 | 显示全部楼层 |阅读模式
I need a 220 volt mig welder it is going to be a millermatic 175 or a lincoln which i don't have a model number for yet.I need opinion good or badsuggestions PLEASEThank YouYour Friendlakehunter
Reply:I have 175 MM Miller that's 5 or 6 yrs old on it's 5th( I think) 10 lb roll of solid wire. So far it doesn't owe me a dime!! I've removed the liner 3 times to clean it and removed the cabinet a couple of times to blow the dust out. So far I'm very pleased with it. I've built many different projects out of 1 1/2" x .060"  salvaged square tube. I have welded non-critical 3/8" beveled and preheated w/ it cranked all the way up.  I bought it new and my grandson is the only other person to use it besides me.                                        MikeLast edited by mla2ofus; 11-16-2011 at 05:02 PM.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:They are good machines but it is an older unit so what Price are you paying for it?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Why not take a look at the MM211? It runs on the same 220V as the 175, but has more than 30 Amps more output than the 175 for a little more money. You can also run it off 120 if you need to use it where 220 is not available. It is the same size unit as the 175 also, just a little heavier, but I'm sure your going to build a cart for either one like most everyone else does that has one. Being a higher output machine it will probably be several years longer before you decide to upgrade, if at all. It's better to get more machine than you think you need now, than to upgrade to more machine later. A lot of the guys on here that have MM211 seem to be very happy with it, and I plan on getting one if I can find someone that wants to buy my MM140. It's a good little machine itself, but I would like the extra output when I need it without having to fire up the Bobcat for higher amperage/thicker material.
Reply:http://www.weldersupply.com/products...es|Mig+Welding  try here for great price. It's not shown  where you are located. The welding supplier is in wisconsin and i have bought from them but pick up only. Go with the 211, best buck for the money, good luck
Reply:go with the mm211. for the the money its the best welder out there.after all these years the 211 with a spoolgun has been out, itshard to beleave lincoln cant even make a welder that comes close to it
Reply:it would appear by the op's post he is looking for a used machine since the 175 hasn't been built in several years. so how is he going to save money by getting a new 211? i have seen 175's as low as $500 bucks with bottle on cl. good luck coming close to that on a 211. my 175 is about 6yrs old. i bought it new and never a problem and going strong and i wouldn't part with it for $800.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Originally Posted by ed macgo with the mm211. for the the money its the best welder out there.after all these years the 211 with a spoolgun has been out, itshard to beleave lincoln cant even make a welder that comes close to it
Reply:the 211 has been out for 2-3 years I think, and lincoln actually just came out with a comparable welder to it.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
GMT+8, 2025-12-23 18:13 , Processed in 0.086857 second(s), 18 queries .
