Anyone ever weld cunifer
发表于 2021-9-1 00:05:34 | 显示全部楼层 |阅读模式
Anyone ever weld cunifer? whats the best process? is it a lot like welding aluminum? is it a pain to work with? just want to find out what this stuff is like to work with
Reply:Hey Toby,Way back('93/'94), the shop I was working had a small job for special fittings that were cunifer. We used MIG, ER CuNi(ER CuNi30) with 90/10(ArH2) for both welding & purging with very good results. It machines decently. Been a while since I've run across anyone using cunifer, although I know it is used in the shipbuilding arena. You may want to post a query on the AWS forum for specific parameters if using code specs.DennyAddendum: Here's a site that has all the data on the filler that will give you composition :http://www.migweld.de/english/produc...-cuni30fe.htmlLast edited by yorkiepap; 11-15-2011 at 03:16 PM.Complete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Originally Posted by yorkiepapHey Toby,Way back('93/'94), the shop I was working had a small job for special fittings that were cunifer. We used MIG, ER CuNi(ER CuNi30) with 90/10(ArH2) for both welding & purging with very good results. It machines decently. Been a while since I've run across anyone using cunifer, although I know it is used in the shipbuilding arena. You may want to post a query on the AWS forum for specific parameters if using code specs.DennyAddendum: Here's a site that has all the data on the filler that will give you composition :http://www.migweld.de/english/produc...-cuni30fe.html
GMT+8, 2025-12-23 18:11 , Processed in 0.092714 second(s), 18 queries .
