Hobart 8500 or champion 10,000
发表于 2021-9-1 00:05:34 | 显示全部楼层 |阅读模式
Ok so I have the chance to guy a brand new champion 10,000 with 2 hours on it new 50ft leads for $2500 or a used hobart 8500 with 25ft leads and cover for $1000. which would you go for. If my reseach is correct the 10k is only 30% duty cycle at 230 amp DC only and the 8500 is 100% at 210 and it does ac or dc. should I go with the used machine because its more capable even know its slightly smaller.Miller Thunderbolt Craftsman Flux core mini migVictor cut skill torch
Reply:I also have the option to buy a Miller Legend AEAD-200LE for $2000Miller Thunderbolt Craftsman Flux core mini migVictor cut skill torch
Reply:tractor supply has the champion elite listed for $3200 brand new and it is a 100% duty cycle machine in ac and dc.  i don't know mmuch about the miller that you had listed, but of the 2 hobarts, the bigger newre machine woud be my choice.  my $.02
Reply:The elite must be the newer model with higher duty cycle.Miller Thunderbolt Craftsman Flux core mini migVictor cut skill torch
Reply:Originally Posted by HOBARTtractor supply has the champion elite listed for $3200 brand new and it is a 100% duty cycle machine in ac and dc.  i don't know mmuch about the miller that you had listed, but of the 2 hobarts, the bigger newre machine woud be my choice.  my $.02
Reply:Originally Posted by 02powerstrokeThe elite must be the newer model with higher duty cycle.
Reply:If he goes the new route for $3200 or so, I'd opt for a Bobcat and get a machine that can do CC/CV for just a bit more. Cyberweld lists them for about $3380.Me personally, I'd want the CV capability. On the machines the OP posted, I'd want the extra aux power of the 10K unit. That said, if the 8500 was relativly low hours, I'd probably make do with the lower aux power to save some cash..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Well the nicer used ones were bought up quick and everything else around here is junk for top dollar. So I'm thinking of saving my money and going new, I have limit space in the back of my service truck so I'm thinking of these two machines.(lincoln Eagle) or (Miller wildcat) But to me it seems like the Lincolns a better deal higher duty cycle bigger generator, but I like the weight of the miller because this is all going in a SRW 250 with a reading utility bed.Miller http://store.cyberweld.com/miwi200endrd.htmlLincoln http://weldingsupplyusa.com/index.ph...eid=6&Itemid=1Miller Thunderbolt Craftsman Flux core mini migVictor cut skill torch
Reply:[QUOTE=02powerstroke;575284]Well the nicer used ones were bought up quick and everything else around here is junk for top dollar. So I'm thinking of saving my money and going new, I have limit space in the back of my service truck so I'm thinking of these two machines.(lincoln Eagle) or (Miller wildcat) But to me it seems like the Lincolns a better deal higher duty cycle bigger generator, but I like the weight of the miller because this is all going in a SRW 250 with a reading utility bed.Miller http://store.cyberweld.com/miwi200endrd.htmlLincoln http://weldingsupplyusa.com/index.ph...emart&Itemid=1Miller Thunderbolt Craftsman Flux core mini migVictor cut skill torch
GMT+8, 2025-12-23 18:12 , Processed in 0.112172 second(s), 18 queries .
