what did i do wrong
发表于 2021-9-1 00:05:32 | 显示全部楼层 |阅读模式
hello from north texas, need advice for a 180 lincoln migHello,Can someone tell me why my 180 lincoln mig will only sputter when i run it on my 7000W gen, but it welds great when i run it from my 220/240 wall outlet in the garage. i have read on here that a 5000W gen will run the mig welder, so i assume i have failed to set something up properly.Thank youScott
Reply:could be as simple as a bad connection in the plug. may be something wrong in the generator as well. Check the voltage at the genorator outlet. see how it compairs.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Does the genset bog down?Did you wire the Cord correctly for genset use?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Might pay to have the frequency checked. It's directly affected by engine RPM.                                      MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:thank you , got it, had my 4 pronged twist wired wrong, 120 instead of 240. Works great nowScott
GMT+8, 2025-12-23 18:09 , Processed in 0.167832 second(s), 18 queries .
