Bid this job.
发表于 2021-9-1 00:05:25 | 显示全部楼层 |阅读模式
I just finished this job and thought it might be interesting to see how you all would have bid this and what equipment you would use. Go HERE FOR FILE for bidding prints. I had three days to get my number in and did not get a chance to look over the site.Ceiling line elevation is 10' 4" ant concrete above is at 16" 6"For sake of arguments lets say the hourly is $52.50 workmans comp is $55.00 per hundred. that way we all use the same numbers.My bid included all materials and labor to fabricate and install (no paint) It also included shop drawings. I put in 15 hours for meetings as this general contractor has weekly mandatory job site planning meetings. The job site is 10 minutes from the shop.  I was told the room is small it is on the ground floor and all the doorways leading to it are 3'0" or betterAfter a week I'll post my numbers and how I got to them I don't know what the point of this is and I don't know how you all will receive this. I just thought it up and want to have a go. Later all
Reply:linky no worky
Reply:Link works, it just doesn't go to where you want us to go!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Where is it taking you? It looks like it works on my end?
Reply:workmans comp is $55.00 per hundred? lol
Reply:Originally Posted by Fat BastardWhere is it taking you? It looks like it works on my end?
Reply:One Million Dollars!....muhuhuhahah..........muhuhuhhahahaha.............muhuhhahahahahaha....Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Originally Posted by busymanworkmans comp is $55.00 per hundred? lol
Reply:stupid fingers made a stupid double post, sorry.Last edited by app-ironworksllc; 08-27-2009 at 12:02 AM.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Originally Posted by dabar39I'm getting the sign up page for google docs
Reply:Originally Posted by app-ironworksllcOne Million Dollars!....muhuhuhahah..........muhuhuhhahahaha.............muhuhhahahahahaha....
Reply:linky stinky
Reply:Email it to me and I'll see if I can convert it to something usable.  I'm brainfarth on gmail as well.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Have you looked at your workcomp rate for steel  erection over 2 stories?  It should be lower.  You pay more for the 2 stories or less because everyone with a pickup, ladder and a welder, think they can do the work.  This makes the rating fall under "unskilled work".  They have a much greater accident rate.  Even though you are using skilled ironworkers, you pay more because of them.  You could check with your workmans comp carrier and see what your MOD factor is.  If it is above 1.0  see what you can do with them to get it down.
Reply:I can't get it either. I don't know anything about google docs, but, my guess is we are not on the list of people that can see it.To make it smaller you have to break it into pieces.Get CutePDF. It is a free download. Install the program.  It installs itself as 'printer'.Open your PDF document normally. Then 'print' it.  When the printer dialog box comes up select  'CutePDF Writer' as your printer and select the number of pages that you want to print, eg 1-5, and then 6-10 etc. Viola, the PDF is broken up.Last edited by RancherBill; 08-29-2009 at 03:14 PM.
Reply:What are the conditions of work.  Do you have unrestricted access or are you working around other trades.  Will it be ready to do all at once.How many bidders? Are there 'price sluts' in Alaska?
Reply:Originally Posted by RancherBillWhat are the conditions of work.  Do you have unrestricted access or are you working around other trades.  Will it be ready to do all at once.How many bidders? Are there 'price sluts' in Alaska?
Reply:Originally Posted by RancherBillI can't get it either. I don't know anything about google docs, but, my guess is we are not on the list of people that can see it.To make it smaller you have to break it into pieces.Get CutePDF. It is a free download. Install the program.  It installs itself as 'printer'.Open your PDF document normally. Then 'print' it.  When the printer dialog box comes up select  'CutePDF Writer' as your printer and select the number of pages that you want to print, eg 1-5, and then 6-10 etc. Viola, the PDF is broken up.
Reply:$55 on a $100.00 is crazy.   I pay $17 on a $100.00 up to 40 ft in colorado.
Reply:Originally Posted by fishpoop$55 on a $100.00 is crazy.   I pay $17 on a $100.00 up to 40 ft in colorado.
Reply:Note, my wife is commercial insurance, both liability and workmen's comp.   Deals with 50 states.  She has huge files, for each of 50 different states.  Both computer files, and her own personal files, in paper.   The rates for one state, have no correlation to the rates of another state.
Reply:Originally Posted by Fat BastardYep that is what I am paying for Iron workers (steel erection under 2 stories) Is that high or low for your area?
GMT+8, 2025-12-23 21:39 , Processed in 0.114308 second(s), 18 queries .
