Welding cast heads on with 9018M
发表于 2021-9-1 00:05:20 | 显示全部楼层 |阅读模式
I am going to be welding some heads onto 3/16" thick 4" box tube. For the battering rams I making. I don't know the exact ingredients yet but supposedly it is cast steel with some moly in it. It requires preheat. I will get the temperature soon. Anyways, does anyone have an idea for preheating say 5-10 heads at a time so I can weld all the heads on at once? Thanks. Dave
Reply:I'd just lay them out on some firebrick and use a Propane/Oxygen torch with a rosebud tip..Lots'o'heat really fast.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterI'd just lay them out on some firebrick and use a Propane/Oxygen torch with a rosebud tip..Lots'o'heat really fast.. ...zap!
Reply:Tough question..I can't answer that with something "concrete" but if they change color..(get a little darker)..then you should be OK.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by turbo38tThanks. I was thinking of maybe laying them on a small rack I have with a torpedo kerosone heater firing on them but that's all I got. Think it would get them hot enough? Dave
Reply:Torpedo heater will work.  Heat em till they smoke.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Just remember, like zap said oxy/propane is the fasest way, if time is esential.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:How thick are these heads?
Reply:Originally Posted by SupeHow thick are these heads?
Reply:Never under estimate the power and precision of the kitchen oven. Find out what temp they need to be and there you go. You can go to an estate sale and get a cheep one to use for baking rods, heating for a press fit and pre heating to weld including for aluminum. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
GMT+8, 2025-12-23 18:10 , Processed in 0.070849 second(s), 18 queries .
