Hi, i'm in the process of setting up a small OA setup for jewelry making. I've used OA in school before but I've never had to set up my own tanks. I've read thru a bunch of stuff and get what I need to do and what i need to not do but when trying to turn my acetelene cylinder valve (its a 3/4" hexnut) with a wrench there feels like theres incredible amount of pressure on it and that to even open it I'd have to force the wrench, ie. not opening slowly, or at least as slowly as I want to, which doesn't seem like a good idea. I'm also not the strongest person. So heres my question, is there something wrong with the cylinder or is it jsut me ie. having never done this on my own before am i being overly cautious? It's sunday today and my local welding supply place is closed so jsut seeing if anyone out there has any insight. Greatly appreciated. Thanks
Reply:Is it like one of these?In all instances, you need to turn the little square silver piece, not the large brass anything. Attached Images"Great spirits have always encountered violent oppostion from mediocre minds." -- Albert Einstein
Reply:They have a compression style seal around the valve stem so as to be sealed in any position. Yours is just fairly tight is all. That's the way they can be."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Originally Posted by razerIs it like one of these?In all instances, you need to turn the little square silver piece, not the large brass anything.
Reply:Don't be afraid of tightening it back up like that either......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I hate the little wrenches you need to use with those valves. I picked up a couple of used scuba valve knobs that fit that square pin perfectly. Most dive shops can either order you a new one, or probably have an old valve they can cannibalize to get you one for a couple of bucks. Just remember to keep the knobs when you return the cylinder for a refill. Attached Images.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:op, that hex thing tightens thepacking..you should spray it with some soap just to be sure when you got done adjusting it it wasnt leaking acet.and dsw..the good thing about the llittle wrench is you could put it on a key chaiin or in yer pocket.. put that knob in yer pocket and you'll appear to have a badly swollen testicle.. |
