seriously help!!!!
发表于 2021-9-1 00:05:16 | 显示全部楼层 |阅读模式
a water can tipped over and got a 25# spool of e71t11 wet how do i save it ?Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Get it in the dumpster fast before the rust makes a mess on the floor.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:If you got to it SUPER QUICK You could bake it like you would stick rod and save it but most likely its yunkVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by SundownIIIGet it in the dumpster fast before the rust makes a mess on the floor.
Reply:lol making me laugh i like that sundownlll lol well i think i saved it ill know in a couple of days see if it gets rusted but i had a empty spool and some alcohol  and paper towels ran it with alcohol then respooled it back on the other one while using a dry paper towel lets see what happens! danng i wold hate to loose all that wireLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:ty for the advice and laughter made me feel better about it lolLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Throw it in the oven at around 300deg for a few hours.  Is it a plastic or paper spool?  300 may be too hot.    Could you spray it down with something like carb cleaner that will evaporate and displace the water?Dan
Reply:it was on a plastic so i didnt want to risk burning the house before thanks giving lol i thought about contact cleaner but dont know if it leaves and residueLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Not to be a smart ***, but will you burn the house down with the turkey fryer?Learning one rod at a time
Reply:It's the flux on the inside that you need to worry about---------toss it6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Originally Posted by Vince_oNot to be a smart ***, but will you burn the house down with the turkey fryer?
Reply:Sell it on craigslist.
Reply:Originally Posted by VPTSell it on craigslist.
Reply:Originally Posted by assassin_works...well i think i saved it...i had a empty spool and some alcohol and paper towels ran it with alcohol then respooled it back on the other one while using a dry paper towel...
Reply:If you think losing a roll is bad imagine when you lose the end of wire down into a 500 pound drum.  No matter what you do when you retrieve the end it will be snarled up.   Half an hour of running and it jams over and over.  I have about a hundred pounds I brought home for tigging steel ( hard wire).  The rest went in the scrap bin.
Reply:First shop i worked in, we had 7 welding stations all set with with 800 pound spools (hobart e71 if i recall)guy thought it would be 'cute' when he quit to spray our spools with what we guess was either brine from heat treat or just plain water...Was many years ago and the judge put him on a payment plan so he MIGHT be almost done paying for it. - Mell of a HessWhen any government, or any church for that matter, undertakes to say to its subjects, "This you may not read, this you must not see, this you are forbidden to know," the end result is tyranny and oppression, no matter how holy the motives.
Reply:If you hurry, maybe you could get a big pile of scrap metal and start burning the wire. That might keep it from rusting!  Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Originally Posted by wb4rtIf you hurry, maybe you could get a big pile of scrap metal and start burning the wire. That might keep it from rusting!
Reply:Bring it to me, I'll put it in my oven, with a plastic spool gotta smell better than my wife's cooking."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by kolotBring it to me, I'll put it in my oven, with a plastic spool gotta smell better than my wife's cooking.
GMT+8, 2025-12-23 18:09 , Processed in 0.096188 second(s), 18 queries .
