Salvaging a contractor
发表于 2021-9-1 00:05:13 | 显示全部楼层 |阅读模式
Would it be possible to take the contactor out of my old ln-25 and rig it up to work with my Lincoln magnum sg?Lincoln Ranger 250 GXTLN-25Lincoln Magnum SG and ModuleAirco HF BoxMiller 304 XMT CC/CVMiller 60 Series FeederMiller Syncrowave 250O/A SetupIt's a dog eat dog world and i'm wearing milkbone underwear
Reply:A contactor is a contactor - provided same ratings, voltage, poles, etc.There are a few exceptions - you can use a double to replace a single but not the other way around.When any government, or any church for that matter, undertakes to say to its subjects, "This you may not read, this you must not see, this you are forbidden to know," the end result is tyranny and oppression, no matter how holy the motives.
Reply:The original LN 25's came with out a contactor in them.
Reply:"Salvaging a contractor"lol...Welding/Fab Pics: www.UtahWeld.com
Reply:Yes.  Just check the input current for the two machines and be sure the Magnum SG does not draw more input current than the LN-25 OR, even better, if you have ratings on the contactor (almost always printed on the contactor body), just be sure that the rated input current for the Magnum SG does not exceed the contact rating for the contactor for the same voltage.  And, of course, as SRO1911 said, you have to be sure the number of poles is sufficient for the Magnum.Is there something more subtle in your question?  Are you asking HOW to rig it up?awright
Reply:Originally Posted by farmallDetox, then Alcoholics Anonymous?
Reply:Oh, and you'd better schedule an exorcism too.
GMT+8, 2025-12-23 18:09 , Processed in 0.071324 second(s), 18 queries .
