Des Moines
发表于 2021-9-1 00:05:12 | 显示全部楼层 |阅读模式
Anybody in Des moines, Ia? I have a 5 minute job I need help with.
Reply:Oh c'mon now... we all know there's no such thing as a "5 minute job." Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Sure there is. It is just a cracked bracket that needs a little more weld poured on it.
Reply:it will take longer than that to pull the leads.................
Reply:Yeah and then you have to figure out which one is the ground. Now that may be hard for some of you I'd bet. I wasn't looking for somebody to weld it for me because I don't know how. I was looking for help because I don't have a welder with me. You shouldn't treat everybody like a newbie just cause they don't have a bunch of posts.
Reply:Heck man..........hit you're favorite waterin' hole, and find someone who talks the talkProbably a bunch of 'em Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by oilfieldtrashinYeah and then you have to figure out which one is the ground. Now that may be hard for some of you I'd bet. I wasn't looking for somebody to weld it for me because I don't know how. I was looking for help because I don't have a welder with me. You shouldn't treat everybody like a newbie just cause they don't have a bunch of posts.
Reply:Ok, picture this...............Ya got a buncha rummies in the bar, mostly because they're unemployed, tellin' each other how good they areNow, ya gotta nother' dude comin' in with the same attitude.  Gotta be a BS fest in the makin'.  Good times all around  ROUNDS ON THE HOUSEEnd of the day, everybody somehow makes it home, and nothin' gets done.Except for some folks tellin' others how good they are.Aw man,  I left the welder in the pickup.  Or...Aw man, I left the welder at home, be back with it tomorrow,  kin I still have a drink?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looks like he didn't get served, and went home"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Oilfield, not trying to put you down because you're a "newbie" - who really pays attention to the post count, anyway?  However, Leadhead is right - there's no such thing as a "five-minute job."  Maybe when you actually get to the welding part, there is, but remember, there's a lot of setup before you can staert welding, i.e., drive time, setting up the generator/welding equipment, pulling the welding leads out, getting suited up for safety, grinding and general cleanup of the parts, etc.  Probably looking at half an hour just in setup time alone before the torch even gets lit.Anyway, so what's the job?  Pictures?  There has to be someone out there in Des Moines that can throw down a bead for you.
Reply:I am going to be in des moines on wednesday or thursday.  what do you need?2 Trailblazer 302's2 HF251-D1'sDynasty 200DXLincoln Powermig 140CHypertherm Powermax 30Airco Torches out the a$$
GMT+8, 2025-12-23 18:09 , Processed in 0.087848 second(s), 18 queries .
