face pass
发表于 2021-9-1 00:05:09 | 显示全部楼层 |阅读模式
heres a face pass pictures.7018 3.20mm down position,i will try on vertical tomorow. Attached Images
Reply:other than the hypnotic joy you are getting from burning rod, which i am known to do for hours, i think  you are ready to stop plate practice and work on fillets and lap joints. it will mean more practice metal to cut clean  and bevel.
Reply:That would make a good backpiece for a waterfall ........
Reply:Anybody who looks at this post and thinks,"you never run 7018 downhill" or, "running 7018 downhill is easy".  they should try running a pad of beads on a weakened medium wall thickness boiler tube in the vertical position, with out popping a hole. Not easy.  Good job Vlima, now you should concentrate on open bevel joint welds, using the flash freezing rods, 6010 or 6011.  Once you get a hand on how to manipulate the flash freezing rod everything else will seem like child's play.all I want in my life are....... white castle cheese burgers
Reply:One of my favorite operations is putting in the root with 6010 on pipe. However I have never heard the phrase flash freezing rod. What are you refering to
Reply:Originally Posted by weldbeadother than the hypnotic joy you are getting from burning rod, which i am known to do for hours, i think  you are ready to stop plate practice and work on fillets and lap joints. it will mean more practice metal to cut clean  and bevel.
Reply:Nice vert groove.  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-23 18:09 , Processed in 0.087647 second(s), 18 queries .
