Air Traffic Control cabin
发表于 2021-9-1 00:05:07 | 显示全部楼层 |阅读模式
hey all, been lurking for a while in the background and decided to throw up some pics of a little project i've been working on for an new international airport.enjoy>main support columns,>partial assembly,>ext upper and lower panel mock-up Attached Images
Reply:welcome   nice job!  looks like a fun project to work on. keep the pictures coming.
Reply:WoW!  Sure beats a welding table.  Does that come apart for transport, or will it be transported like that?
Reply:fun to start, but that novelty quickly wears off. just those columns had about 3 weeks of prep work and the weld/assembly took me almost 8 weeks to completeunfortunatly, during the rest of the assembly i was in Trinidad on an installation and when i got back everything was pretty much completed. right now there's about 6 containers on boats headed overseas to the job site. (i follow in about a month's time...). i'll see if i can snag some shots of the stair case we had to fab (24 flights) in the next couple of days for another similar project.@ JC everything gets broken down, cleaned/prepped/painted, and what we can't do before hand gets done in the field. all part of the installation process.>test fit-up jig for roof beams>center hub>roof assembly in process Attached ImagesLast edited by Unklmo; 06-07-2009 at 12:30 PM.
Reply:To have it all fit must be a real sigh of relief.  No minor reworks I hope.Your people do the assembly on site, or is it up to another contractor?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammTo have it all fit must be a real sigh of relief.  No minor reworks I hope.Your people do the assembly on site, or is it up to another contractor?
Reply:That goes a long way in getting rid of the "cry baby" factor when someone on the other end can't get it to work because they aren't doing it right"Any day above ground is a good day"http://www.farmersamm.com/
Reply:wow.  what country is this going to, if i may ask?
Reply:Originally Posted by oxy moronwow.  what country is this going to, if i may ask?
Reply:hey guys, been a while since last posting.  now that i'm on the other side of the world (at least from my home) here's a link to see some of the progress here in Nigeria on the ATC cabin installation.http://s830.photobucket.com/albums/zz223/Unklmo/ @ FarmerSamm always some minor reworks to be done. usually referred to as "calibration" (7/8ths reamer) and "re-calibration" (the sledge )
Reply:That thing in the first pic,is that a portable fume remover to remove fumes while welding? I was gonna call that a fumigator lolDrink a Guinness Draught....Millermatic 140Do you still rememberDecember's foggy freeze --when the ice thatclings on to your beard isscreaming agony.
GMT+8, 2025-12-23 18:10 , Processed in 0.091414 second(s), 18 queries .
