harbor frieght tig pics
发表于 2021-9-1 00:05:04 | 显示全部楼层 |阅读模式
anyone got pics of their welds using the harbor frieght tig welder. thanks
Reply:My brother bought one and it works great for non critical weld. Nice clean arc and stable. The only problem is the duty cycle is crap you spend more time wating on it to cool than you weld it seems like it anyway. For ocasional use there fine but if you use it often you might want to move up a little. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:http://www.honda-tech.com/zerothread?id=1433370There is pictures throughtout the threadLast edited by WANNAWELD; 12-07-2007 at 09:08 AM.
GMT+8, 2025-12-23 18:09 , Processed in 0.090231 second(s), 18 queries .
