thoughts on this tig welder?
发表于 2021-9-1 00:05:03 | 显示全部楼层 |阅读模式
im thinking about buying it for something small to use. it seems like a good deal. check it outhttp://cgi.ebay.com/80-Amp-120Volt-M...QQcmdZViewItem
Reply:For $89 dollars, you really can't go wrong. You won't be welding aluminum with it, but you could do thin wall steel, and learn a lot with it.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:yea. i just want to use it on small things like sheet metal. is this a harborfreight unit? it looks like one of those arc one units?
Reply:For under $100 bucks you wont be out too much money.  If it last a year of occasional use you'd get your money out of it.  When it fries itself I would just trash it a look for a good welder.I would stay you should be able to weld 14 0r 16 gauge material at the max.Ron ShopFloorTalk Millermatic 350P, M-25, M-40 gunsDynasty 300DX, Coolmate 3, Crafter CS-310 TorchTrailblazer 302, 12RC, WC-2430A spoolgunSpectrum 2050Thermal Arc Plasma Welder PS-3000/WC-100B
Reply:Originally Posted by welderShaneyea. i just want to use it on small things like sheet metal. is this a harborfreight unit? it looks like one of those arc one units?
GMT+8, 2025-12-23 18:11 , Processed in 0.090515 second(s), 18 queries .
