First welding prject...a cart, of course
发表于 2021-9-1 00:05:02 | 显示全部楼层 |阅读模式
I've enjoyed looking at pictures of other projects on here so I thought I'd some too.  Its just a simple little cart for my Hobart Handler 180. Attached Images
Reply:Man that looks sharp! Great job!
Reply:Nicely done
Reply:That's a nice looking cart!  Just make sure you secure that gas bottle.  I didn't see anything to keep the bottom of the bottle from moving around and no chain or anything around the top.  Small ratchet straps will do the trick until you come up with something better.Great job though, looks good.Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Looks nice enough to be in a dentists office.  Nice work.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by Leadhead1911That's a nice looking cart!  Just make sure you secure that gas bottle.  I didn't see anything to keep the bottom of the bottle from moving around and no chain or anything around the top.  Small ratchet straps will do the trick until you come up with something better.
Reply:Not only built well, but it has professional styling ! .....nice job -Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:Excellent style and craftmanship! John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Nice Cart!  Would you mind taking pic of how the main wheel was mounted??  I'm new learning welding myself and I can't figure out how I would mount the bigger wheels.  I found a 3 feet threaded rod from my hardware store but can't figure out how to mount it.  I'm thinking of just welding it at the bottom but there might be a better option for it.  Thanks//Jo
Reply:Originally Posted by stormNice Cart!  Would you mind taking pic of how the main wheel was mounted??  I'm new learning welding myself and I can't figure out how I would mount the bigger wheels.  I found a 3 feet threaded rod from my hardware store but can't figure out how to mount it.  I'm thinking of just welding it at the bottom but there might be a better option for it.  Thanks//Jo
Reply:thanks for the idea!  You really did a great job on yours.  Take care! Happy welding.
Reply:You did a extraordinarily super great job on that cart. Spark safe Why do you put two cents in when its only a penny for your thoughts? Miller Thunderbolt AC/DC Millermatic 150
Reply:Man, top quality work there, that is one sharp looking cart.  WAY too clean for my shop LOL.  Excellent job!Have a Jeep Cherokee?  Click Here!
Reply:now cut out enough pieces to make 100 and offer them for sale then you ccan buy a welder that wont fit on a cart.   very nice job you can be proud of it.Life is tuff,so be sharp  lincoln sp 100  cutmaster101  miller bobcat  miller 250 mig  $thousands in snapon
Reply:Originally Posted by asemasternow cut out enough pieces to make 100 and offer them for sale then you ccan buy a welder that wont fit on a cart.   very nice job you can be proud of it.
Reply:My compliments to the Chef... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by Josh705X2 Very nice! Were did you get the mats for it? I have been looking for some mats like that for my tool box. Very nice
Reply:I'll bet if Hobart saw the fit with their machine that they would wish they sold it as a package that way!Nice job. Looks PRO all the way!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:very nice cart good jobChuckASME Pressure Vessel welder
Reply:very clean. good job.
Reply:Originally Posted by Rade0041I would take a picture but I kind of screwed it up.  What I tried to do was have the solid 5/8 rod just welded across the bottom of the frame and have it stick out 3" on each side.  I accidentally cut it too short.  I ended up cutting that piece in half and welding each piece to the frame.  I clamped a piece of angle iron to the frame and squared that to the frame and just let the rod rest against it while I tacked it in place.  I still need to thread the ends of the rod so I can put a nut on there to hold the wheels on.  You could probably do the same with the threaded rod but it is probably plated you may want to remove the plating before you weld.  You could drill through your frame, put the rod through and hold it in place with a couple of nuts but what fun is that if you have a welder, right?
Reply:I had to register just to say what a nice cart that is. Can I ask how you matched the Hobart paint?I've been jealous of the Miller and Lincoln guy's matching their cart's paint to their welders - now I see a Hobart guy has done it too!
Reply:Originally Posted by BattiI had to register just to say what a nice cart that is. Can I ask how you matched the Hobart paint?I've been jealous of the Miller and Lincoln guy's matching their cart's paint to their welders - now I see a Hobart guy has done it too!
Reply:OK, Ford Tractor Gray it is. I wouldn't have guessed that!
Reply:I like the cart.  Nice work.Miller Dynasty 200DX Tig WelderThat is too clean. Looks sweet.
Reply:hello Rade0041 Can you post a material list for you cart? It looks like 1X1 and 1x2
Reply:Looks niceMe!
Reply:Now that's a nice clean looking cart! I would expect to see it used in a hospital or a food preparation facility. Really nice job you've done there. Congrats!Miller 302 Trailblazer/Custom TrailerMillermatic 350P/Spool gunMillermatic 252Miller Spectrum 875Miller Dynasty200DxHypertherm Powermax 85Tracker CNC 4X8 Pro Table (Down Draft)Visit us @ www.specialtyrepairscustommods.com
Reply:Great looking cart! What size tubing did you use? Looks like 1x1 Thickness? You've given me some great ideas for my cart. thanks!
GMT+8, 2025-12-23 18:12 , Processed in 0.066947 second(s), 18 queries .
