A very simple stand to make for whatever....
发表于 2021-9-1 00:04:58 | 显示全部楼层 |阅读模式
Pretty basic, easy to make, can use pipe, tubing, or flat, 60 degree cut, weld the three pieces together and you are done.  This happens to be 1.5 square tubing, 0.120 wall, with a 45 degree end just so you don't stub your toe.  Very stable. This is not my claim to fame, saw this concept on a blacksmith's site and ran with the idea.  This was born out of necessity, I wanted a disk off one of the pieces of farm equipment, can't remember what they are called, but none to be found out here in the desert.  This happens to be  stand for a propane forge.  Attached Images
Reply:Nice!  Really, really nice!  This concept can be used for lots of things that require only light duty but portable support.  In only seconds I can see several applications for this design!  Thanks for sharing!-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:ive made some threelegged tables, the transition from triangle to square is always challenging...how is the stability?
Reply:Really nice job,  Particularly like the  support arm,fully adjustable every way, Does it extend thro' the upright to gain extra length?Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Gordon--it does go all the way through the square upright.  This allows both front and back support if a long piece need heat in the middle.  Weldbead--it is very stable, even though the forge is heavy and somewhat top heavy, I am very happy with the stability.  It would take a good shove to knock it over.
Reply:I like it, I like it !!!  Simple, nice, clean and well thought out !!!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Nice, clean and simple - I like it.  DEFINITELY gonna steal this idea .....
Reply:I will be building a small forge soon and I was wondering what kind of stand I was going to put it on. Now I know, thanks for the post.I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Nice design and looks like it can hold some weight. I built a similar triangle stand before but yours has a nice curve feel to it.Happy Welding
Reply:Very cool designThanks for posting the pic'sMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:I like the designMiller Dynasty 200DX Tig Welder
Reply:And if you have an uneven floor like I have, three small feet will stop it rocking around.Yeah, I carry.House keys, wallet, some change, usually a newspaper, maybe a pen.
Reply:neat design... what are you using it for?Adam MMorales Ranch
Reply:3 legged "tripod" designs are one of the most stable designs out thereIt bridges the gap when a truly stable 4 legged design isn't feasableLooks good"Any day above ground is a good day"http://www.farmersamm.com/
Reply:itsadam1--it will be used to hold a propane forge used for Blacksmithing.
Reply:Wonder if it would have been a good idea to add a triangular plate cut perfectly to fit? You know what I'm talking about?Dynasty 200DXNo MIG as of yet....
Reply:Originally Posted by farmersamm3 legged "tripod" designs are one of the most stable designs out thereIt bridges the gap when a truly stable 4 legged design isn't feasableLooks good
Reply:All our jacks to lift airplanes were tripods.  Lifting a 15-40 ton airplane requires a lot of lifting power.  The jacks were triple stage & the jack handle was run by armstrong.  3 jacks per plane, one supervisor to monitor & raise it level.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
GMT+8, 2025-12-23 18:10 , Processed in 0.071331 second(s), 18 queries .
