what do you call it?
发表于 2021-9-1 00:04:55 | 显示全部楼层 |阅读模式
What do you call the space where the "arrow" side of a piece of metal meets with the "other" side of another piece of metal?
Reply:Must be home work.  It is the root gap or weld joint gap.. depending on the type of joint.
Reply:Yeah, it is homework   it is the actual space where the two pieces meet
Reply:i would call it a JOINT if they touch and the GAP if there is space between them
Reply:Seriously? That is way too easy! Thanks!
Reply:Sounds to me like you forgot to do your home work or you could talk about something interesting.
Reply:Bevel or double bevel?
Reply:/facepalm..Buy American, or don't whine when you end up on the bread line.
GMT+8, 2025-12-23 18:09 , Processed in 0.068374 second(s), 18 queries .
