Question about gas tanks..
发表于 2021-9-1 00:04:50 | 显示全部楼层 |阅读模式
My friend is selling his industrial sized oxygen tank for oxy acetylene welding. Could i empty the oxygen and put mig shielding gas in it without problems?Thanks
Reply:No, there are a lot of problems, just don't try.  John      Welcome and you have to trust someone.SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by NSXTACYMy friend is selling his industrial sized oxygen tank for oxy acetylene welding. Could i empty the oxygen and put mig shielding gas in it without problems?Thanks
Reply:Never put what goes in certian pressure vessels in substuted pressure vessels.. The concequences can be severe......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Most large cylinders are not customer owned and when you return a cylinder that is not yours, they will keep it, also the valve has to be changed from CGA 540 to CGA 580.  I also refill O2, N2, and C-25 40 cuft cylinders and that can be very dangerous if you get the cylinder yur filling gets to hot.  It could explode.  Don't even try.  Dave is correct about everthing else.   JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:not only can you not do it. you will not find anyone who will even attempt it
Reply:Above posters who say it can't be done are correct. Get the right cylinders for the proper gases and forget about everything else. You'll be glad you did.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
GMT+8, 2025-12-23 18:08 , Processed in 0.183715 second(s), 18 queries .
