mm 251 on generator
发表于 2021-9-1 00:04:49 | 显示全部楼层 |阅读模式
can u run a 251 on a bobcat trailblazer or pro 300 if notwill it work on a guardian systems
Reply:I tried to run one on an older Bobcat that was 8kw and it was not enough. If it is a 10kw it will be close to full power. It should be ok to run on 10kw or bigger. Any brang is fine you just need the wattage thats all. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
GMT+8, 2025-12-23 18:10 , Processed in 0.092507 second(s), 18 queries .
