a new design for our hole opener line
发表于 2021-9-1 00:04:44 | 显示全部楼层 |阅读模式
24'' and 36'' in the same tool Attached Images
Reply:Artificial Christmas tree?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hole opener? In what? I mean, it looks like a drill bit for oil drilling. Would'nt want it to fall on my foot. Pretty bad*** looking. How much does it weigh?Good judgement comes from experience.Experience comes from bad judgement.
Reply:looks like someone does directional drilling.  Nice.
Reply:holy cr@p!! GEARS of warish!
Reply:I wondered where my big unibit went....
Reply:Originally Posted by jtrapperHole opener? In what? I mean, it looks like a drill bit for oil drilling. Would'nt want it to fall on my foot. Pretty bad*** looking. How much does it weigh?
Reply:Originally Posted by handtpipelinelooks like someone does directional drilling.  Nice.
Reply:I still think it'd make an awesome artificial Christmas tree.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55I still think it'd make an awesome artificial Christmas tree.
Reply:Jaysus, that's a wicked-looking thing ............ Hey, wasn't that piece in the movie "Total Recall", one the front of that big tunneling machine?
Reply:thats a hell of a roto rooter. lol
Reply:Here's a question that I've always wanted to ask someone. How do you control the direction of a drill? I understand the length of the drill pipe will bend but how do you control/aim  it?.....Mike
Reply:the direction of the drill string is controlled by a locator in the drill head.  it gives depth and pitch so you make corrections at the machine.  what's in the picture here is used on the pull back to widen the hole. basically this goes in after the pilot bore is done.  When I used to work at Ditch Witch, our down hole tool department used to make several sizes of these reamers.  some used the mill tooth heads and others used tungsten carbide cutting heads.Salas Repair General Welding & Fabrication
Reply:Just in time for my next dentist visit...
Reply:reminds me of that scene in total recall where Arnold is being chased by the tunnel drill.
Reply:mrmikeythese types of reamers will obviously ride the bottom of the hole because of weight.  These types of reamers are typically used in rock drilling situations.  No beacon to show direction because the pilot bore has already been made.  to make the pilot bore you need a beacon housing with a tapered bit.  the beacon housing followed by the drill string will poke out when the drilling path is taken.  after it pokes out of the ground, the beacon housing is then taken off and this beast is put on.  the size of the reamer dictates what size pipe casing will be pulled back attached to this reamer with a swivel.  the reamer enlarges the hole and the casing is pulled back as dead weight because the swivel only allows the reamer to turn.  I hope this makes sense.Salas Repair General Welding & Fabrication
Reply:When will the DOT approve it for highway use?  I want to drive it to work!
GMT+8, 2025-12-23 18:10 , Processed in 0.069663 second(s), 18 queries .
