Filler rod and gas prices
发表于 2021-9-1 00:04:35 | 显示全部楼层 |阅读模式
Curios what do you all pay for your tig rod and argon? I just bought one lb of er70s2 x 36" and it was 10.18$. I was looking online and I saw that for like 2.50 a lb. I'm all for supporting local but at 4x the price??? 100 cu argon was 60$. I wanted alum filler but it was near 20$ a lb. Wtf???HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:I pay around the same for argon..The argon is what kills me personally, the rod seems to last quite a while..I bought 1 lb of 70s2 about a year ago and am only now getting to the end of it..But I have been through maybe 4 or 5 bottles of argon in that time..This is Just light home shop/personal welding projects
Reply:How do u burn through that much gas with no filler?? 1 lb is nothing.HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:If you buy any type of filler metal in the smallest possible quantity, they are going to sock it to ya (not just local, anybody).  The last time I bought any was 10lbs of 1/8" s2 and it was less than $40 shipped to my door from Indiana Oxygen.
Reply:I'd rather get 10 lbers. Were is a good online source to order from then?HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:I just got it from ebay since I.O. sells a lot of stuff on there.  It was $36.80/box, shipped.  Price is slightly higher for smaller diameter wire.  Just do a search for "tig wire" and you'll get a couple pages of stuff to look at.
Reply:Originally Posted by fordmanCurios what do you all pay for your tig rod and argon? I just bought one lb of er70s2 x 36" and it was 10.18$. I was looking online and I saw that for like 2.50 a lb. I'm all for supporting local but at 4x the price??? 100 cu argon was 60$. I wanted alum filler but it was near 20$ a lb. Wtf???
Reply:It was praxair. But dang thats less than half for the gas.. Where are you getting these deals on everything? Id like to buy filler for those pricesHTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:Originally Posted by fordmanIt was praxair. But dang thats less than half for the gas.. Where are you getting these deals on everything? Id like to buy filler for those prices
Reply:Airmix wants $58 for a S cylinder of Argon  and the T cylinder, steelmix for my mig runs $78.
GMT+8, 2025-12-23 20:00 , Processed in 0.113601 second(s), 18 queries .
