Bar Ash Tray
发表于 2021-9-1 00:04:26 | 显示全部楼层 |阅读模式
Up here in New York, you cannot smoke in bars anymore. With the way they do the gas plumbing today, I almost don't blame them. Ha-ha.This bar in particular had a lot of leaks. We mercury tested it and it fell to zero inches from about 12 inches, in under a minute. It was like that for years. The place next door kept calling the local gas company until they turned off the gas. It needed to be re piped, the leak was in the wall, that separates the two stores. But they needed a garbage can cover with an ash tray. I cheated a bit. I used the fact that a power roller, causes a slight flat in the material when you roll it. To create that starting flat that will fit over the garbage can. Once I cut and rolled the four pieces. I just held them in the right position and mitered them, on a chop saw. Welded them up in a few minutes.   In under ten minutes gave them a nice polish job with a stainless tooth brush wire brush, and some Flitz polishing cream and floppy thing. I got that from http://www.Eastwood.com.I like it.        Sincerely,             William McCormick
Reply:With the Flitz, when you get done with the floppy thing. You have to get a clean towel, and by hand go over it to shine it up. It really does not shine until you use a towel to get off all the black metal and powdered compound. That ash tray gets beach sand put into.        Sincerely,             William McCormick
Reply:Looks nice William. I like the way the Al sides are rolled.Last edited by sidthss; 09-16-2009 at 12:51 AM.Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:Very nice.  I like the rolled sides.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Nice Job!  Those are really nice......almost too nice.  How long do you think it will be until some moron steals one!  Oh well, then you'll probably get to make some bucks welding up the replacements!
Reply:Very nice! MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Nice job William, functon With STYLE!Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Wow,That is one good looking Ash Tray !I've got about 200 sq feet of that diamond plate here that I need to do something with....  An Ash Tray like that seems like a great place to start (I could use the practice...).Curious, is that Ashtray made from 5 pieces ?  I'm assuming that the bottom is of heavy Gauge AL. and is folded up in the corners and then welded in the corners only ?  Are the top pieces then added ?Sorry for the questions, but I'm a NEWB...  Cheers,  /Jman...
Reply:great weldsLast edited by Scott Young; 09-16-2009 at 11:09 AM.
Reply:That turned out very nice. I'll bet you they start walking off though.
Reply:The welds on the transition from the rolled side to the vertical interior of the ashtray"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by jmanWow,That is one good looking Ash Tray !I've got about 200 sq feet of that diamond plate here that I need to do something with....  An Ash Tray like that seems like a great place to start (I could use the practice...).Curious, is that Ashtray made from 5 pieces ?  I'm assuming that the bottom is of heavy Gauge AL. and is folded up in the corners and then welded in the corners only ?  Are the top pieces then added ?Sorry for the questions, but I'm a NEWB...  Cheers,  /Jman...
Reply:Perfect !Thanks for letting me know..., I was going to ask about some type of leveling system, but you answered that too!Cheers,   /Jman..
Reply:Hey Bill, what bar is that for ... I think I'll go and swipe it and then you'll have to make them another one...its a win - win. Great work, i like the way it slopes and transitions from the wider base to the narrower pan!
Reply:Originally Posted by MetalArchitectHey Bill, what bar is that for ... I think I'll go and swipe it and then you'll have to make them another one...its a win - win. Great work, i like the way it slopes and transitions from the wider base to the narrower pan!
Reply:I thought of a great idea for an ash tray.  Miller 330 a/bp water cooledI believe in gun control, I hold my gun with two hands.  If you want to know why, click here.Buy American or bye America.
Reply:Originally Posted by pinjasI thought of a great idea for an ash tray.
Reply:Nice, very nice!!   It would take me much longer than it took you.   Thanks for sharing.keith The older the boys, the more expensive the TOYS!!Previous owned;Linde 300 Amp welderMiller Gas drv welder, Tumbstone,Dayton Miller ac to dc converter,High frequency unitLongevity LS60PCurrrently owned;Longevity WeldAll 200PI
GMT+8, 2025-12-23 23:13 , Processed in 0.078507 second(s), 18 queries .
