Homemade Grain Trailer
发表于 2021-9-1 00:04:26 | 显示全部楼层 |阅读模式
Does anyone know where i can pick up plans or ideas on building a homemade grain trailer.  I can't afford to buy a new one so i figured i try my hand at building one.  Any ideas would be appreciated. Thank you
Reply:My Dad and I were just talking about the same thing last night. Are you looking for something like a gravity wagon on a gooseneck frame? An old grain truck converted to trailer? Totally new from ground up?Better have a little more info on this one.
Reply:In the cotton producing areas there are lots of old cotton tlrs laying around due to almost everyone going to the module builders. Would that running gear be strong enough for a grain tlr? I'm sure you could pick one up cheap.                                   MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I took an old 2-Ton truck frame with the axle and all and built a gooseneck tongue for it. I used 2 lift cylinders and a 12 volt electric hydraulic pump. I could pull it with my 1-ton but in the end it was just too small. I sold it and ended up buying a 600 bushel bobtail from an estate sale. The trailer worked well and I wish I had pics, but this was before the digital age and I never took pics of stuff like that then. I had no plans and as usual, I just started it and luckily it worked out..............................."Look Good Doing It"!!!!!!!!!!!!!!!
Reply:ksfarmer30,call me.I am from south central KS. and have built a few grain haulers from scratch.(318)332-3441
Reply:I'm looking to build one from the ground up. double hopper all steel to pull behind a semi
Reply:Your best bet would be to find one at a consignment auction or someplace like that.
Reply:You would be MUCH better served by starting with an outside rail flatbed and modifying the floor into bottom dump hoppers.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-23 20:00 , Processed in 0.102505 second(s), 18 queries .
