new trailer
发表于 2021-9-1 00:04:25 | 显示全部楼层 |阅读模式
going to put my 225 bob cat on the frontand want to fab a winch that will pull up a 3/4truck so maybe a 7000 lb er have a job to R&Rall the olive branches in a hotel any ideas on a good winch Attached Images
Reply:would the welder be to much to put in the front of the wood planks
Reply:On the tongue? Bobcat looks like 530lbs.  That's a lot of tongue weight for an empty trailer...Last edited by Boostinjdm; 09-24-2009 at 11:17 PM.My name's not Jim....
Reply:You should try it! There are ways to counter the extra weight if it poses a problem. You can add airbags to the truck. They make all sorts of helper springs, you can also add a weight distributing hitch. Those are very capable of leveling out heavy trailers, but you won't know until you load it up! I will say to watch for turning clearance with the truck bumper, the pinch point should not endanger the Bobcat because the day may come when you back up a bit too much in a turn and pinch something. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-23 21:36 , Processed in 0.105883 second(s), 18 queries .
