bamboo construction
发表于 2021-9-1 00:04:22 | 显示全部楼层 |阅读模式
I´m making the brackets for a bamboo structure.I´m going to refresh the posts with the avances Attached [email protected]
Reply:This is center part of the structure. Attached [email protected]
Reply:You can see the brackets (galvanized) Attached [email protected]
Reply:I'm going to post more pictures of the big structure soon.This are the brackets of an smaler structure.They are made from 1" and 2" wide 1/4" thick. Attached [email protected]
Reply:I'm welding it whit 6013 at 72 amp.Not sure if the mexican coin is a good reference  but its similar to a US quarter. Attached [email protected]
Reply:Nice !That looks like a FUN project !That Bamboo is pretty 'amazing' stuff.  Recently learned that is actually a type of GRASS and that it can and will grow up to 12 inches in a single Day !  I found it incredible that it's cellular structure is the strongest on the planet and that it is actually able to support load bearing forces above that of STEEL   Mind boggling stuff.....  Nice looking welds BTW.Cheers,/Jman...
Reply:That Bamboo is pretty 'amazing' stuff. Recently learned that is actually a type of GRASS and that it can and will grow up to 12 inches in a single Day ! I found it incredible that it's cellular structure is the strongest on the planet and that it is actually able to support load bearing forces above that of STEEL
Reply:Originally Posted by SoldadorI'm going to post more pictures of the big structure soon.This are the brackets of an smaler structure.They are made from 1" and 2" wide 1/4" thick.
Reply:Jaja I already buy a new brush [email protected]
Reply:More pictures of the structure.Concrete. Kind of coliseum Attached [email protected]
Reply:more imqages Attached [email protected]
Reply:the brackets... Attached [email protected]
Reply:I  made 260 pices Attached [email protected]
Reply:wow thats a cool project
Reply:brilliant
Reply:Nice design for a roof structure. Be sure to finish with more pic's. What will the roof be covered with? Love the coin weld comparison. What coin is that?Good judgement comes from experience.Experience comes from bad judgement.
GMT+8, 2025-12-23 23:11 , Processed in 0.108167 second(s), 18 queries .
