welding table question`
发表于 2021-9-1 00:04:21 | 显示全部楼层 |阅读模式
I am looking to build a new table my old one is 36 inchs high I was wondering how tall yours guys are or how tall I should make mine I am 5 9 work standing up.
Reply:Read somewhere that the best work table height is 6 inches below your elbow with arm against your side. For me that works out to 42 inches and that height is comfortable for me at 6 foot tall.Ranger 250 GXTSmith Gas Axe
Reply:My table is 38 inches high and I have no complaints.  I am 6' 2"
Reply:I´m 6' 2" and my 35" table works good for [email protected]
Reply:I like a short table so when I set stuff on it I don't have to stand on a step stool.  A short table also works well with a chair sometimes.My name's not Jim....
Reply:All depends on what you are working on and what height you feel comfortable working at. Everyone here can give you numbers on their benches, but that bench might not be where you are comfortable at....... its almost a guessing game the first time you make a bench, but you can always change the hight later.Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:"Read somewhere that the best work table height is 6 inches below your elbow with arm against your side."That's more or less what I have read too--that your workbench should be high enough that when your vise is mounted on it, the jaw tops are at elbow height.  Tim
Reply:Like dinner table - 39".
Reply:As my uncle once told me, "pecker high"
Reply:Best option, make it adjustable.Ranger 250 GXTSmith Gas Axe
Reply:Originally Posted by wicrulesAs my uncle once told me, "pecker high"
Reply:im 5'10" and mine is 41" high.  i'm a hobbyist and everything i do is bench welding, so i can sit on a stool or just bend over a little bit.I had a table that was 39" tall, and it didn't "look" right, so i cut it down to 36".  big mistake.  so when i was making my serious-table, i made sure i get it to the height i want.  and 41 seems to work out pretty good so far.
Reply:MINE is adjustable between 24 in.&48 in. 5insq. tube inside of 6in.sq.tube with 1in. pin holes every 2in.
Reply:Originally Posted by RUSSELLMINE is adjustable between 24 in.&48 in. 5insq. tube inside of 6in.sq.tube with 1in. pin holes every 2in.
GMT+8, 2025-12-23 20:00 , Processed in 0.105967 second(s), 18 queries .
