how much
发表于 2021-9-1 00:04:15 | 显示全部楼层 |阅读模式
power would it take to operate a licoln tombstone? I am wanting to use a generator.
Reply:The Lincoln catalog shows the AC225 wants 50 amps @ 230v, 63 amps @ 220v to run at max.  For the ACDC225/125, it shows 36 amps for DC on 230v, and 41 amps for DC on 220v to run at max.My Bobcat 250 is a 10,000 watt generator and makes ~45 amps at 240v.  I would estimate to run DC at max you would need at least an 8,000 watt gen and to run AC at max, 11- or 12,000 watts should do it.For how much a generator of that power costs, you would save money to just buy a Bobcat that already has the welder inside it.  You can get a nice used Bobcat or Ranger welder with 8-10KW of generator power for around $1500.   The generators I have seen in that power range for sale cost more than that and don't include a welder....MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Fortunately I should have a Ranger 8 by days end. Going to look at one today
GMT+8, 2025-12-23 19:56 , Processed in 0.067110 second(s), 18 queries .
