Mig like tig
发表于 2021-9-1 00:04:09 | 显示全部楼层 |阅读模式
I am the one that says "If you want it to look like TIG, the get out the torch".  These are bucket shanks.  Pulsed spray mig, .035 @ 250 ipm or .045 @ 200 ipm wire, 92/8 gas.   Its a big gap, the shanks have a bevel and there is a gap between the shank and cutting edge.  I went ahead and back as I went along. Welds are on a small incline, I went up.I don't have a dime, but the cutting edge is 3/4" for scale.Last edited by David R; 01-10-2008 at 10:46 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Those look good. Pictures tend to take away some of the beauty of nice mig welds, so spot on Mr. R.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:They're looking very good! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Sweet! Where's the dime?  Or would we need a quarter for this one?  HA!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Dang... You are to that big stuff, what ZAP is to the little stuff.  I'm skeered to crank my machine up that high, all that bangin' and clangin' goin' on inside the welder. My squirrels would be trippin' over each other trying to spin the wire out that fast!The best things in life all come on a stick!
Reply:A forward whip, you can get the same result without the pulse. Gravity and a steady twitch. You sure are loving that new board. Maybe I never really gave pulse a chance to like it, I just prefered doing it manually.Edit; BTW, looks good as usual !!Anything worth doing is worth doing RIGHT
Reply:Nice looking welds Dave.Keep up the good work.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Originally Posted by olddadA forward whip, you can get the same result without the pulse. Gravity and a steady twitch. You sure are loving that new board. Maybe I never really gave pulse a chance to like it, I just prefered doing it manually.Edit; BTW, looks good as usual !!
Reply:Nice work!I will be burning some 1 inch plate today but I,ll be using 7018.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:nice welds!!
Reply:Pretty soon you'll catch ZTFab!! Nice work David.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:thats slickComplete Fabrication Shop specializing in pipe fabrication. Also offering heavy steel fabrication and sheet metal work.
Reply:Funny, when I saw 'mig like tig' in the title, first person I thought of was ZT Fab.   David has been practicing .MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Nice welding Dave. I pulsed the last set of shanks the I welded on a track hoe bucket I rebuilt. I was kinde playing around and we runing 450ipm of .045 er-70 wire on my 350P and it looked good as well as penetrated great. Let me know about the metal core wire I have used it on non pused mig and it was ok but I want to try it on pulse.Today I started a 26' aluminum sliding gate and had a blast welding with the pulsed MIG. Everbody should try it out and give it time enough to learn how to use it. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:Hard case.   Over in the south seas here we call them adapter's and would put another three runs on there at least, and no I'm not saying there wrong, in fact nice looking welds...I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:Those shanks are way too big for the bucket.  Today My son and I are doing a BUNCH more.  There is a chamfer on the shank About 45*, and 3/8 wide.  All the welding is done in between the shank and cutting edge.  There is also a gap between the shank and cutting edge.  Its a big gap.  I put a piece on 1/8" tig filler in the bottom of one to help keep the weld in one place.  The wire rolled under the shank and stayed there.  More pics today.  Offrdfun73  The metal core wire did not come in yesterday   I have 1/2 of a 30 lb coil of .045 dualshield, then its .045 bare wire pulse spray mig for the rest.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:nice looking welds I get to do some of those about every other year, used'to do them with a oa tourch and stick about a days worth of work for 5 , now with the plazma cutter and wire feed I can do 5 in about 2 hours ,this is on a 24" bucket with 3/8 welds.i use a nickel sized forward and backaround stroke withmiller 250 cranked way up and wire speed to fit almost to a spray. havent had one brake yet.Life is tuff,so be sharp  lincoln sp 100  cutmaster101  miller bobcat  miller 250 mig  $thousands in snapon
Reply:Wirehunt I have done 3 sets for a guy here and the box had in big black letters "shank". The bigest bucket was 40" wide and had 6 shanks. It is on a 175hp track hoe and he digs in rock all day because that is all we have and he told me I was the only person to ever weld them on for him that they did not break off in 3 months. This one has lasted for 6 months and no craks. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
GMT+8, 2025-12-23 20:00 , Processed in 0.112164 second(s), 18 queries .
