The ATV threw off drive chain, broke off chain guard bolt pads and broke hole in stator cover. I used carbon rod in bolt holes to keep from welding them shut. Bored broken seal area to size, drilled out carbon rod and installed thread inserts. Dressed welds w/carbide burrs then sanding rolls.Pre/post heat to 350, TIG with 4043Peter Attached Images
Reply:Wow!! Looks like it never happened!Where do you get your carbon rods?http://all-a-cart.comWelding Cart Kits and accessories
Reply:Originally Posted by ZTFabWow!! Looks like it never happened!Where do you get your carbon rods?
Reply:Awesome job! Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:Originally Posted by Leadhead1911Awesome job!
Reply:Originally Posted by castweldThanks, I have admired some of your posts. I guess someday when I am not in a hurry and am having a "on day" (these are getting fewer and farther apart!) I'll take pics of nice welds and post.Carbon rod is a copper coated gouge rod. When using like this the arc will "wander" over to the carbon, it conducts really well.Peter
Reply:You used carbon rod to keep from filling the holes. Q: When finished welding, is the rod easily removed? as in the rod simply slides out? Or, do you have to drilled it out then repair the threads? Thanks.OOps, reread your original post. I got it.
Reply:Very, VERY nice work. Now can you weld cooling fin extensions on my '83 XL600 head?
Reply:Nice work, cast aluminum is tricky.
Reply:Originally Posted by zombie-stompVery, VERY nice work. Now can you weld cooling fin extensions on my '83 XL600 head?
Reply:Originally Posted by bLu-Z64Nice work, cast aluminum is tricky. |
