1 and 2 outta 3
发表于 2021-9-1 00:04:07 | 显示全部楼层 |阅读模式
Start at the with the oldest end with the newest. It didnt really occur to me to take up close photos or to bring a better camera the just the one on my phone. These are "custom" aluminum grilles. Not really a whole lot special with these things. Just kinda oversized and annoying. (this one was 38 inches by 76 i think)Secondly and something I am much prouder of is a two water fountain restoration job I did here in the city. A decent chunk of the job was union only, so unfortunately I didnt have anything to do with some of it.The first picture is 3.5 x 3.5 stainless tube frame/grid for the fountain spout support.This second picture shows a fiberglass grid intended for us to mount light fixtures.Just some different views.After the fiberglass grids have been bolted into place, the light fixtures mounted, and the stone put into place.If you look between the last two pictures you'll see the angle between each row of water spouts. The angles are meant to hold glass.These last two photos are bent stainless sheet for stone support. The drains are under said sheets. The mirror finished plates are scrap pieces that I used for brace support.
Reply:Looks great,I wanna see it in operationMillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
GMT+8, 2025-12-23 20:00 , Processed in 0.117641 second(s), 18 queries .
