Stick welding cold roll
发表于 2021-9-1 00:04:04 | 显示全部楼层 |阅读模式
Is their any special with welding cold roll steel? I have to weld some 3/4 thick flat cold roll steel to hot roll square stock.  I was going to put a root pass in with 6010 and then cover with 7018. Thanks]Lincoln PT 225 Tig
Reply:other than not having mill scale,  and warping more than hotroll,  nothing special.XMT 350 MPa, w/D52-DTA 185 TSWHarris of
Reply:Thanks for the response, I'm going to get this project done now. I have not worked with cold roll to much and wanted to make sure that I did not have to do anything special.]Lincoln PT 225 Tig
GMT+8, 2025-12-23 21:38 , Processed in 0.091256 second(s), 18 queries .
