211 Heat Range
发表于 2021-9-1 00:04:02 | 显示全部楼层 |阅读模式
If You Switch From 230V Back To 115V Will It Change Your Heat If You Stay At Same Setting ? - No One At Work Can Answer
Reply:If you have the machine, try it and answer your question for us. Might be the only way to find out for sure. Don't think it will if the range is set outside the parameters of the 120v range.
Reply:It Did Seam To Do Better On 115V - Welding 18 Gauge - Barn Door Track -.035 Wire - 75/25 Mix - Thanks For Reply
Reply:Just looking at the charts for your machine it does look like the power output does slip down a bit when you go to 120v from 230v. At the very lower end of the scale almost negligible but on the upper range it slips quite a bit more to the point of some voltage levels and certainly amperage levels out of reach. So the short answer for all practicle purposes is no, don't expect the same characteristics if switching back and forth from 120 to 230 at a lot of settings."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Yes. Less power in on a setting, less power out at that setting.[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
GMT+8, 2025-12-23 21:39 , Processed in 0.071782 second(s), 18 queries .
