i just bought a new arc welding machine here are the specs to my machinehere my arc welder specsRATED OUTPUT CURRENT 200 AMPRATED CURRENT VOLTAGE 110-220 VOLTSRATED FREQUENCY 50-60 HZRATED INPUT CAPACITY 10.5 KVANO LOAD VOLTAGE 50VRATED DUTY CYCLE 20%RATED DUTY VOLTAGE 26 V.CURRENT RANGE 65-200 AMP110 -220 Vanyone know what the right size generator i need to get thanks
Reply:Originally Posted by bob_jones40i just bought a new arc welding machine here are the specs to my machine...RATED INPUT CAPACITY 10.5 KVA......RATED DUTY CYCLE 20%...
Reply:thanks for ur help
Reply:A small Bobcat 225 would be ideal. I got my Bobcat 3 for $3100. A 10.5kw generator will cotst you $2000 or more. The Bobcat has a 9.5kw constant generator built in. You can also get off road wheels for it if you just want to roll it around. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B |
