Acetylene Ash
发表于 2021-9-1 00:03:52 | 显示全部楼层 |阅读模式
Just a quick question - it may sound really stupid...Was firing up the oxy-fuel rig today and noticed ash like particulate floating down directly after getting the acetylene lit - had not introduced oxygen to the flame yet. It happens every time I light the torch rig - does anyone have an explanation for this. Acy. Regulator Press. - 12ish PSI (Drawing off of memory)Thanks, jakeDo you really know all of the work that goes into getting that fish onto your plate?
Reply:Thats acetylene for you, propane, and mapp don't have the "little witches".Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Those are called XXXXXX paratroopers.  Insert racial slur.  I dunno.  Old welder slang.
Reply:at temperatures above 900 degree C the main product is soot.soot is a dark powdery deposit of unburned fuel residues, usually composed mainly of amorphous carbon. also called lampblack or carbon black.nothing to be concerned about, it will do it every time.G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:That will happen all the time , its just carbon.Burn off of the gas.It goes away once you turn on oxygen.
Reply:known as welding crows, just turn up your starting flow and it will go away.Life is tuff,so be sharp  lincoln sp 100  cutmaster101  miller bobcat  miller 250 mig  $thousands in snapon
Reply:My high school thecher told us to crack the oxegen befor we lit but I refused. Like asemaster said turn up the gas a little and no soot. By the way dont let that soot touch anything it is neerly imposible to make that crap go away. On a side not a female friend did not want to be in shop class so when it was her turn to light the torch with a rose bud well you can guess. A small class room full of soot and my friend was gone. I was pissed because of the soot but is was funny watching the teacher lunge for the torch. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:By the way dont let that soot touch anything it is neerly imposible to make that crap go away.
Reply:Ya my wife made me go and replace a towel I was useing to dry off some water one day outside so I could cut a small plate. It got SOOOOOTTTEEEDD bad. She would not even let me try to wash it. Steel Thunder Welding LLC. St. Thomas VI USAMM350PBOBCAT 3MAXSTAR 150 STH375 EXTREME PLASMA6.5 HP COMPRESORDEWALT 18, 24, AND 36 VOLTO/A TORCH SETAND SO MUCH MORE I DONT REMEMBERALL IN MY 2005 2500HD EXTENDED CAB L/B
Reply:Turn up your flow on the fuel before igniting. The correct fuel flow for acetylene is when no smoke or "soot" is produced at the proper pressure.SA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T  D-XL75,SpoolMate3545SGA100C,HF-15-1  RFCS-14 When I stick it, it stays stuck!
Reply:I was taught in a welding class to use the soot from the acetylene when welding cast aluminum.  Clean your aluminum really well and get is all prepped.  Then coat the piece with sooty acetylene flame until it is black.  Then start to preheat the piece.  The soot burn right off when the piece reaches a hot enought temp. to weld on it.  A guy was working on a part of a motorcycle in the class and used this method the teacher said to and it worked well.
Reply:is it just me or is 12psi a little high for acet. ?? i am always around 5psi on the acet. and 12-15 ish for oxy if cutting, and about 3-5 on both when welding. O/A can be a very dangerous tool, a class for proper use would be greatly recommended. and please be shore to have flash back arrestors on your O/A rig.FWIW; you would be much better off with a good name brand than one of the e-bay cheepo's. some tools were just not meant to be bargain basement value.the soot is used a lot in aluminum, also good for loosening it up before bending/working it. summer is here, plant a tree for mother earth. if you dont have time or space, sponcer some one else to plant one for you.feel free to shoot me a PM or e-mail me at [email][email protected] i got lots of time.
GMT+8, 2025-12-23 19:58 , Processed in 0.099136 second(s), 18 queries .
